AHHHHH gas leak.......help?
Old Sep 23, 2008 | 10:07 AM
740SkiWagon's Avatar
Default AHHHHH gas leak.......help?
OK so..... The leak is coming from the subframe area of the fuel pump.....roughly under the drivers seat.
I got home last night and pulled out the fuel relay with the car running to cut the gas feed
now..... what are the historical chances it is a line? the fuel pump? the fuel sender?
can the pump spring a leak? can the lines be snipped and refit if it is a line?
any help please!
Old Sep 23, 2008 | 11:03 AM
bubba240's Avatar
Default RE: AHHHHH gas leak.......help?
The previous owner of my 240 had the main pump and filter replaced. The shop used a cheap fuel line to go between the two and eventually it cracked. The proper connection uses a banjo fitting (740 same as 240) and sometimes people forget the copper crush washers which leads to leaks. Sounds like a good inspection is needed.
Old Sep 24, 2008 | 12:12 AM
tedv's Avatar
It's probably a line/clamp thing. Of course, you'll never know until you look-just get in there and it will be pretty obvious. Be cautious with gas leaks.
Old Sep 24, 2008 | 09:15 AM
welllll - to the best of my 'just-got-home-from-work-looking-under-the-car-with-a-headlamp-why-is-it-already-39-degrees-in-sept-in-north-pa-knowledge' it looks like the filter.....not sure if it was stock or not (its a 1990) .........but the damn thing looks cheaper than a coffee can
i couldnt find any gas on the pump or line connections......seems the filter just cracked or something - its rusty as hell
anyone know what i should expect in terms of gas flow when i get this puppy off?
or any tips?
Old Sep 24, 2008 | 09:48 AM
bubba240's Avatar
I wouldn't clamp the outsidehose, instead have several diameters of plugs around for inside the hose when you remove it.
Old Sep 24, 2008 | 01:06 PM
thanks guys! as soon as this part lands on my porch im going to be on my way - and able to park the SUV and back in the Big Black Brick - (thats the semi dirty name for my wagon because the ladies love it, not) - "Once they go Big Black Brick they never go back" haha
on a serious note - i am also going to keep one of those cone shaped size adjustable errrr twistable wine corks - my co-worker said it works well in a pinch for this application
wildbill
Jul 26, 2009 07:09 AM
1999S80T6
Dec 16, 2008 04:54 AM
c70turbogt
Mar 2, 2008 03:20 PM
dman777
Jan 23, 2008 12:08 AM
jollygoodgold
Jul 16, 2007 12:06 PM
