Air Conditioning issues 90 740 GL
It's unrelated to the recharging, I believe. There is a small check valve that has failed. Engine vacuum controls the air flaps in the car. At wide open throttle, there is basically no engine vacuum. There is a check valve on a large tube that comes off the intake manifold, then goes to a smaller one. That's the part. It's regularly kinda disc-like and white towards the manifold and black on the side that's away from the manifold. Here's one: Climate Control Check Valve
I would check locally first.
IMHO, you have a failed/leaking vacuum motor under the dash. However, the vacuum motor that fails is supposed to be a PITA to replace. If you are willing to do without full floor air, you can solve the problem by plugging the yellow vacuum hose (I used a broken spark plug) which is located on the driver's side above and to the right of the accelerator pedal. You will still get some air to the floor by going to the position that splits the air between the dash vents and the floor; you just won't have it going to the floor only, and your A/C will blow all the time through your dash vents, even under full acceleration, as it's supposed to.
I am having the exact same problem with my 91 740 turbo wagon. The vents work great at idle and they switch from floor to vent to defroster with no problem but as soon as I drive the vehicle they quit blowing out of whatever vent is chosen. When I come to a stop it starts blowing again. I couldnt find that check valve anywhere but I havent looked real hard yet. Gonna mess with it today. I live in CA so we must have good working a/c here! If I figure it out I will post it.
I found the problem with my a/c it is a vacuum operated bellows/servo under the dash on the drivers side. There is 3 of them and it is the one with a red vac line going to it, it has a slow leak. I put a vac pump on it and only holds for like 30 seconds, I was told that they are a real pita to replace so I am looking to add a vac cannister to just that 1 line. I will probably get a cannister off of a 240 at the salvage yard and install it behind the glove box. I will let you know how and if it works.
sabin333
11-02-2014 09:11 AM
