Am I doomed?
Old Dec 6, 2007 | 02:16 PM
Goober's Avatar
Default Am I doomed?
I've got a 91 940se turbo that will not run. It cranks over ok. The spark plugs are wet, and it has low compression.
1=80, 2=75, 3=80, 4=80. I tried oiling the cylinders, but the compression did not rise at all. New plugs just wet. I got a code 312 but I dont believe its related. I think its washed the cyinder walls down and ruint the rings. [&o]
Anyone have any suggestions. Any help is appreciated.
Thanks, Tim.
Old Dec 6, 2007 | 06:35 PM
Default RE: Am I doomed?
You might have something wrong with the valves if oiling would bring the pressure up.
Oiling seals the rings to raise compression.
audihenry
Nov 18, 2012 06:47 PM
soapboxhero
Oct 6, 2006 07:26 PM
