Amber fog light high beam
Old May 13, 2013 | 04:49 PM
Godfather1960's Avatar
Default Amber fog light high beam
hi,
where can i buy the hi beam amber/fog light head light ..i have the clear hi beam ones just wanted amber
1984 volvo 244 dl
Thanks in advance
Old May 13, 2013 | 06:29 PM
wait. FOG lamps are used with LOW beams, not high beams, they provide a low to the ground wide field of light with a sharp cutoff at the level. DRIVING lights are auxillary narrow beam lights used in conjunction with HIGH beams. yellow is sometimes used with fog lamps, never with driving lamps, and AFAIK in most states, yellow is illegal on your main headlights, only on auxilliary fog lamps..
your 84 240 has the quad rectangular lights, yes? there are no driving or fog lights stock unless you have a 242GT or something with the extra set of lights in the grill, or some sort of aftermarket lights on the bumper.
so what exactly are you looking for here?
Old May 13, 2013 | 07:09 PM
thanks pierse,
i have seen cars with quad lamps and the two where the high beam ones go is the ambers ..kind of like this guy.. gives it a cool look and might help here in the florida frog choking fog/humidity
Datsun 510 521 620 621 280ZX Amber Fog Light Headlight Set NEW
Old May 13, 2013 | 08:00 PM
well, that link is full of fail. high beams are NOT fog lamps.
so you want yellow high beams? are those 200 by 142 mm (7.9 by 5.6 in) or 165 by 100 mm (6.5 by 3.9 in) units ? (I've not had a quad-rectangular lamped 240, and don't know offhand what size it uses).
you can get lamps to replace those that use H4/H1 halogen bulbs, and you can get those in amber. for instance these,
Susquehanna MotorSports - Auto Performance Product
(which are the 165x100mm size), and Susquehenna will even include the 55W Amber lamps for you.
Old May 13, 2013 | 08:12 PM
i remember my friend had them on his 1976 pontiac grand prix which was 4 eyed and it looked cool just a vision brother i dont' need high beams if all possible
rebhanoli
Apr 12, 2008 10:08 PM
jfunez
Mar 7, 2006 03:52 AM
stealth42o
Feb 21, 2006 04:19 PM
M46Power
Nov 1, 2004 04:58 AM
M46Power
Oct 9, 2004 12:17 PM
