Another 240 brake light problem
Old Apr 13, 2018 | 06:35 PM
nathank's Avatar
Default Another 240 brake light problem
I've read a lot of posts on here about 240 brake lights not functioning. I have a 1989 240 DL and none of the three brake lights work. All other lights work. I've checked:
  • The fuse is good and I get continuity across the fuse
  • The bulbs are good
  • The brake light switch is good. I get voltage and continuity across the switch terminals.
  • I pulled out the bulb failure relay and checked for continuity across all the pins having to do with the break lights
Any other ideas? The only thing I thought might be a little off is that the voltage between the brake light switch terminals is 5V. I would have thought it would be 12V.
Old Apr 14, 2018 | 09:07 AM
jagtoes's Avatar
Find out why it is 5 volts and when you get it to 12 volts the lights should work.
Old Apr 16, 2018 | 01:55 PM
one side of the brake switch (the green-red wire) *should* be 12V relative to chassis ground, that comes from fuse 7, the other side goes to the bulb-out sensor, and from the BO it goes to all 3 brake lights on separate wires, and the other side of each brake light goes to ground.
nealeas
Mar 24, 2018 09:59 AM
jameson
Oct 15, 2015 06:14 AM
Jonboy
2001-2013 model year V70
Apr 17, 2013 11:12 PM
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
