Another 240 Odometer ?
Old Apr 17, 2008 | 01:14 PM
JWTX's Avatar
Default Another 240 Odometer ?
Started the next project on fixing up this 240, 1991 model. The odometer was not working when I got it. Took it appart and yep broke gear. Ordered and installed a new gear. Re-installed in dash and odometer still does not work. Took it appart and rechecked for debris. Reinstalled and still does not work. I did notice that when I removed the odometer from the dash the motor was warm.
My question: How to I test the odometer motor without reinstalling it and driving the car? I would like to know if the motor is working or not. Also any other ideas to what could be wrong?
Old Apr 18, 2008 | 01:04 PM
JWTX's Avatar
Default RE: Another 240 Odometer ?
So I'm not one with much patience. I'll tell ya what I did not diagnose/fix the problem though I don't recommend it...
Pulled the cluster and checked it again. For kicks and grins I retin'd the three wire connector pc board. Add a little di-electric grease. Reinstalled. Jacked car up and place on 6 ton jack stands. Pulled the connector off the pickup on the pumpkin. Cleaned and added di-electric grease. Re-installed. Cranked the car and started driving. (sorta) When 1.5 miles at 25MPH and never left the garage.
Problem fixed I think.It was late so I plan on putting the dash back together tonight and test driving it.
Since I did the retin and clean of pickup at the same time I am not sure which fixed it. I noticed that when connecting to the back of the cluster the connector seemed loose. After retin it is tight. After reading about all the corroded electrical issues on the 240's I have been putting di-electric grease on every electrical connector I take apart. Also I already re-did the fuse box.
Fogducker
Mar 17, 2016 02:18 PM
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
atherpres
Jun 12, 2007 08:22 PM
atherpres
Jun 4, 2007 10:21 PM
