Anyone need any parts?
Old Aug 25, 2014 | 07:45 PM
Blue91SL's Avatar
Default Anyone need any parts?
Hey guys, was just up at the junkyard today, and they have TONS of older Volvos. 940s, 740s, 850s, and a 240 sedan with black interior.
There were also some newer cars. Normally I wouldn't offer to do this (time constraints) but there are so many cars there that I will be returning for myself, so I figured I'd offer to pull anything for anybody who needs something. If so, speak now.
Old Aug 25, 2014 | 10:50 PM
where are you located ?
Old Aug 29, 2014 | 10:44 AM
admasters's Avatar
Default Yes!
I am looking for speaker grilles for 7 or 9 series doors.
Andrew
Old Sep 1, 2014 | 08:10 AM
Blue91SL's Avatar
Located in/near Anderson, SC.
Also, did the 7/9 series cars come with multiple speaker sizes? I'll take a look and see what's there.
Old Sep 1, 2014 | 12:08 PM
afaik, they are al the same. not all have all speakers. little speakres on dashboard, larger speakers in drivers door, midsized speaker in passenger doors
two kinds of grills, interior colored plastic ones and black metal ones for the door speakers. the metal ones are better from an audio perspective (thinner)
Old Sep 3, 2014 | 12:31 PM
dnarby's Avatar
I'd be interested in turn signal/running light lenses for an '89 sedan & a '91 wagon. Mine are in decent shape, but eventually...
I wish I had some land, I'd start my own 240/740 boneyard.
Old Sep 6, 2014 | 09:38 AM
817rlb2069's Avatar
Recently purchased 86 244 and I am learning but have owned two other Volvo's in the past. This 86 has the window molding trim popping up on corners and I need to learn how to fix that. I have not been able to locate new trim for the windshield any suggestions should I judge that it all needs to be replaced.
Old Sep 12, 2014 | 01:13 PM
that4wdwagon's Avatar
Do they have an alternator for a 1993 940 non turbo?
Old Sep 14, 2014 | 01:59 PM
HECTORPORTALUPPI's Avatar
Hi!
I need two horns for a 1994 volvo 940 turbo wagon.
I am in california. 91331
phone: (818) 768-3194
thank you.
Hector.
Old Sep 19, 2014 | 12:44 AM
Blue91SL's Avatar
I'll check for all of these parts very soon, guys. Hopefully heading up Saturday. Need to get a new high beam switch, hoping that will make mine work. Maybe they'll have some new 240s.
Old Sep 19, 2014 | 01:39 AM
Ohh, also a intermittent wiper relay and turn signal flasher relay, and the alternator tension bolt, I don't think I need the alternator anymore
Old Sep 19, 2014 | 01:47 AM
Originally Posted by HECTORPORTALUPPI
Hi!
I am in california. .
get a 2-tone pair of fiamm or hella horns. the 500Hz/300Hz supertone pair will knock the socks off any iphone addled moron in your path, heh. there's a ton of room behind the grill of any 240/740/940 for horn of choice. if your horn kit comes with some tabs of springy metal, DO use these for mounting them, that makes them louder.
$60
Robot Check Robot Check
Old Oct 10, 2014 | 03:38 PM
Blue91SL's Avatar
Alright guys, I made a trip to the yard, and they've crushed a lot of stuff, but there are a few good cars as well.
'94 Volvo 940 Turbo. Has about 183 on the clock. It's in decent shape, but a lot of good stuff is gone. Turbo parts look good, but the nose is done for. If anyone needs stuff off of it, let me know.
[URL=http://s48.photobucket.com/user/joe_greer53/media/Junkyard%20Nation/unnamed3.jpg.html]
EDIT: The beige 244 has been crushed
Old Oct 10, 2014 | 03:41 PM
Blue91SL's Avatar
Lastly, a '92 wagon. T-boned, everything special about a '92 is broken. Odo says 318k. Car looks like it ran awesome before the side was destroyed.
Old Oct 10, 2014 | 03:43 PM
Blue91SL's Avatar
Andrew
I found a set, but two of the holes the tabs go in are damaged. Otherwise they are in good shape. Are you interested in them?
Old Oct 11, 2014 | 02:16 PM
250 thousand miles+'s Avatar
Hi, I am looking for a engine for a 1990 Volvo 740 Turbo. The distributor is on the cylinder.
Thank you
Old Oct 11, 2014 | 02:27 PM
  #17
you mean, the distributor is on the camshaft.
a 1990 740 T should be able to use the engine from any 1990-1995 740/940 turbo. the 94/95 turbos have enhanced oil cooling on the piston skirts for greater longetivity.
an engine block is way too massively heavy to be shipped, short of a dedicated truck with a 1 ton fork lift, which would be prohibitive, so you probably should say where you are.
Old Oct 11, 2014 | 10:20 PM
  #18
Blue91SL's Avatar
Thank you
What he said.
Although, depending on location, I would be willing to deliver (obviously for a fee). Again, depending on location. I'm on the east coast. If you're in California, you're out of luck. If you're within ~10 hours of me, I'd consider it. Although bear in mind that at this particular junkyard, they do not test the vehicles, so that engine is an as-is kind of deal. But I can't say for sure that it isn't damaged, because of the condition of the front end and the fact that the alternator is on the intake manifold.
Old Oct 15, 2014 | 04:04 PM
  #19
240 Guy's Avatar
Are your sorry that you asked yet? I know I am responding a bit late, however, if you go back anytime soon or if anyone else sees this, I am looking for a complete set of body side molding for a '90 wagon.
Old Oct 15, 2014 | 05:17 PM
  #20
Blue91SL's Avatar
Lol, not really. I'm a part of four different types of car forums that I post in regularly, and I do the same for pretty much everybody. So it's one of those things I'm used to. I just have to learn more about these than I have Stealths/3000GTs, or Galants, or Cressidas.
Time isn't an issue, I tend to go fairly regularly and I keep my eyes open for unique cars. It's always CAMRY CAMRY CAMRY COROLLA CIVIC ACCORD, but sometimes it's CAMRY CAMRY SUPRA ACCORD CIVIC BMW. And I always try to make unique stuff for some of my cars that don't have much in the way of aftermarket, using stock parts from other cars.
Are you looking for the upper trim that goes along the sides of the doors? Or are you looking for the lower trim on the bottom panels? Both sides?
