Automatic shift knob replacement?
Old May 21, 2014 | 11:02 AM
Spyros's Avatar
Question Automatic shift **** replacement?
Hello!
I just bought a great 1995 940, really the only issues with this car involve interior cosmetics. For example, the (rubber?) material ball on the automatic shift **** is completely chipped and worn away. I tried doing a search on ebay for "Automatic shift ****" on my car, but only standard ***** come up.
Any ideas on how I can replace this? Is it too big of a job to justify with cosmetic issues?
Old May 21, 2014 | 03:07 PM
lev's Avatar
lev
REMOVING GEAR SHIFT ****
ADIS instruction:
Pull **** straight upward from the lever.
Considerable force is required to remove the ****.
I'd pop out the OD button and use some lubricant to free things up--these ***** are on there TIGHT!
Old May 22, 2014 | 01:21 PM
Spyros's Avatar
Does this apply to the automatic gear shift lever? Your link to ebay presents the same issue, these are all for standard shift levers. They do not include the single button to shift out of Park on an automatic transmission.
Thanks!
Old May 22, 2014 | 03:04 PM
lev's Avatar
lev
Don't know how that ebay link even got in there...
These instructions are for the automatic shifter removal.
Old May 22, 2014 | 03:07 PM
does this 95 940 have hte 'handle' style gearshifter, with the park lock on the front side and the OD button on the back side, or is it the older style thats more of a rectangular **** with the park latch button on top, and the OD button on the left side?
newer style:
older style:
both look to be pushed on. I bet getting it really warm with a hot air gun before removing would greatly help.
Old May 23, 2014 | 10:47 AM
Spyros's Avatar
It is the newer handle style. Thanks for the info this should be really helpful. Now the only problem is that I can't find a shift lever that will work in this car, apart from the OEM, which is $75 on ipd and I can't find it anywhere else. No aftermarket shift ***** seem to be compatible with this, as the button is on the front.
Old May 23, 2014 | 11:03 AM
you might try tascaparts.com or volvopartswebstore.com both are actual volvo dealers that sell dealer parts online at a discount, and are often cheaper than IPD or FCPeuro.
or, troll junkyards.
StephenAki
2001-2013 model year XC70
Aug 14, 2015 01:11 PM
martymcfly1985
Jul 29, 2014 02:36 AM
Karnage
Nov 20, 2009 05:21 PM
jfspring
Jan 29, 2006 12:00 AM
