Automatic transmission woes
Old Nov 2, 2013 | 01:19 PM
Travanion's Avatar
Default Automatic transmission woes
Good morning ladies and gentlemen,
I have a 1988 240 DL wagon with a AW70 auto trans. As I dropped my wife off at work yesterday the car began to buck a bit and then lost forward dive. Upon lower car inspection I realized that the culprit was all the ATF pouring out on the ground. I have a fair amount of automotive experience but this is my first automatic Volvo which I recently purchased. I had the car towed home and have gone as far as to drop the the trans mount bracket and lowered the trans but can't see where the fluid is pouring out from. It is running down the left, driver side of the transmission and coming from the top. It is not the over drive solenoid or the selector shaft seal. It is coming from the top out of view. The torque converter is dry and the cooler lines are not leaking. Any advice on this would be greatly apriciated.
Old Nov 2, 2013 | 03:13 PM
there's nothing up there that should be able to leak, unless the transmission case is cracked or something.
Old Nov 2, 2013 | 03:28 PM
Travanion's Avatar
Unfortunately that is what I was thinking too. I have looked over my Bentley manual and can't see anything up there either.
Old Nov 2, 2013 | 03:39 PM
can you get an inspection mirror up there to take a better look?
Old Nov 2, 2013 | 07:34 PM
Travanion's Avatar
I believe a gentleman on RWD nailed it. There is an overflow tube on the top. I think the valve body has looked up. It was not wanting to shift from 1st to 2nd unless I shifted into N and back into 2nd before it started puking. Thanks for the help Pierce.
mathieu_p
Jan 19, 2013 02:06 PM
hawkguy09
Oct 25, 2010 06:17 PM
BRDVPRA
Nov 28, 2009 08:23 AM
Muskoka
May 9, 2009 09:54 PM
Cactus52
Mar 21, 2007 10:26 PM
