Auxillary Ground Wire
Old Jun 25, 2007 | 11:04 AM
daver80's Avatar
Default Auxillary Ground Wire
Folks- this is an application for a non Volvo, (BMW R80RT motorcycle,) but does anyone know a guage equivalent to a 30 amp rated wire? Will be installed as an auxillary, dedicated ground line. Thanks! Dave
Old Jun 25, 2007 | 04:44 PM
wojeepster's Avatar
Default RE: Auxillary Ground Wire
Why not just look at the wire attached to a 30 amp fuze? (I don't know the size) Bigger is better and be sure to use stranded wire. If you are going to crimp connections use a real crimping tool (klien tools at lowe's) the cheap ones allow you to pull the connector off with your hand, something you should not be able to do. Also allows corrosion which increases resistance and allows voltage drop. I would guess 16-10ga will be aedequate. The twenty five amper on volvo fuel injection is pretty thick wire, go look.
Old Jun 25, 2007 | 10:30 PM
daver80's Avatar
Jeepster- Thanks for the helpful words. Looking at the wire on a 30 amp fuse was suggested by the guys at NAPA, wasnt sure if that was the right way to do it. The (just adequate) charging system on this old bike must transition through many different engine/tranny components. and my battery isnt quite getting the volts it should have. This little trick should insure an uninterupted line between battery and alternator. I will look at the fuel injection wire as you suggested. Bigger is better! You know, I hate those crimp on connectors. Dont trust them- gimmee a soldering iron any day! Thanks for the assistance! Dave
Old Jun 26, 2007 | 09:07 PM
wojeepster's Avatar
dave, thought you might like tracy martins book on motorcycle electrical systems can't remember the exact title but he has another one how to diagnose and repair automoble electrical systems. Best book I ever read on electrical systems and I have read over a dozen. You can get it on amazon.com for under $20 I never really understood electrical systems until this book, it made it all easy
howardr
Feb 9, 2011 05:47 PM
nkachrani
Jun 20, 2008 02:11 PM
ko_kidd
Jul 10, 2007 02:16 PM
dssing
Feb 2, 2006 08:56 PM
kaz
Mar 14, 2005 05:49 PM
