B230 swap into 84 242 - A Few Questions
Old Dec 11, 2014 | 12:35 AM
djnoir's Avatar
Default B230 swap into 84 242 - A Few Questions
Hi all.
I currently drive a 1984 242dl, b23 standard, and I recently bought a 1989 244dl parts car.
I'm going to start a full interior swap as my 242's dash is in pretty sad shape, and I like
the color of the 244s interior much better. Not to mention heated seats :grin:
Anyways, the b23 in my old 242 has seen better days, and is starting to get pretty tired.
How much would go into dropping the b230 in place of the b23?
The b230 is mated to an automatic gearbox right now, would the flywheel off my 84 fit?
Is the bellhousing compatible? Are there any other issues I might face?
Thanks in advance!
Old Dec 11, 2014 | 04:11 AM
AFAIK, the blocks are bolt compatible. lets see, yeah, both 84 and 89 automatics used the same flange to mount the flexiplate, that means the bolt holes are the same, so yeah, your 84 B23F flywheel should bolt up to the 89 B230F engine, and as far as I know your existing manifolds and EFI and stuff should bolt up, too. switching to the 1989 LH 2.4 and EZK ignition might be challenging, not sure if your flywheel has the timing marks that LH2.4 requires for its crank position sensor.
babinke
Oct 27, 2014 07:34 AM
snowtyres
Jul 1, 2014 09:27 AM
AnEskimo
Jun 8, 2013 09:12 AM
_eac_
Nov 8, 2006 02:38 AM
Vanos
Aug 15, 2003 03:36 PM
