B230FT and B21
Old Sep 5, 2010 | 10:48 PM
fochmann's Avatar
Default B230FT and B21
Ok, So I am out to turbo my 90 240DL and I have purchased a B21 complete turbo motor with all the lines and everything. My question is it possible to take a head from a B230FT and use it on the B21 Turbo motor with using the B21 exhaust manifold and the intake from the B230FT?
Also, I have the getrag 5 speed currently in my volvo; will the transmission, I believe it is called M47, bolt to the B21 block?
I am going to do a complete rebuild no matter which way I go. If I need to get the B230FT block I can and just use the B21 parts for the air cooler and other miscellaneous parts. I have a Garrett T3 Turbo, The B230FT Cylinder head from a 91 and the injectors and intake manifold, a complete B21 Turbo motor and all the lines and injection system for the B21 and the exhaust system.
I really just don't want to use the k jet injection system
Thank You for your help.
Old Sep 6, 2010 | 06:26 AM
swiftjustice44's Avatar
Yes, you can use a the 530 head from a B230ft on a B21ft. Yes, the M47 will bolt right up. Folks have also used the B21 head and just swapped the intakes...just seal the injector holes in the B21 head w/ freeze plugs. Search on turbobricks.com What you're contemplating has been done often.
Old Sep 6, 2010 | 09:53 AM
fochmann's Avatar
Ok, Thanks so I do not need a 530 head, I will see which one is in better shape.
Duanob
Aug 3, 2012 11:20 AM
swiftjustice44
Mar 24, 2011 04:19 PM
mhfowle
Feb 15, 2009 03:16 PM
wbr
Dec 8, 2008 05:08 PM
Mad-Ass
Jul 25, 2004 05:22 AM
