Back to the begining. What would cause...?
Old Jun 26, 2007 | 10:26 PM
mercedesguywithvolvo's Avatar
Default Back to the begining. What would cause...?
What would cause the Battery light to be on after the car was off and key removed with igntion fully off? The problem started when the alternator went bad. The light would be on with the car off but not with it on. We replaced the alt. then the car kept stalling and it apparently has a short somewhere. We have tried differnt batteries but to no avail. So what would short to cause the battery light to stay on after the car is off?
Any info would be greatly welcomed
Thanks
Mercedes guywith volvo
[align=left] [/align]
Old Jun 26, 2007 | 10:29 PM
Default RE: Back to the begining. What would cause...?
Bad wiring harness will cause that to happen.
The engine harnesses are very bad on these cars.
Old Jun 27, 2007 | 12:40 PM
well thats great. Looks like my weekend, or the next several, are runied lol. So I likely need a harness
Old Jun 27, 2007 | 05:44 PM
You could very well need one.
I have seen then cause that problem before.
Try running a new wire from the grey plug at the firewall to the Alt. and see if it fixes it.
Old Jun 27, 2007 | 07:42 PM
wojeepster's Avatar
power to the light is turned off when you turn off the ign switch. When you turn key on power goes to light and is grounded at the alternator. When car is started and alt is charging there is 12v on both wires (ign switch and alt) running to light (no ground) and the light goes out.
rspi
Mar 13, 2013 10:17 PM
rspi
Jan 10, 2012 12:03 AM
bigsparky
Sep 13, 2010 06:55 PM
JimKW
Dec 4, 2008 08:08 AM
