Battery light question
Old Mar 16, 2011 | 01:33 AM
cyclist01's Avatar
Default Battery light question
My battery light stays on even when the key is removed from the ignition switch..Can someone please tell me what could cause this?
Car is a 88 244 with a new alternator that tested out in good working condition
Old Mar 16, 2011 | 06:23 AM
swiftjustice44's Avatar
Well, the simplest answer would be thatsomeone miswired the terminals on the alternator. If no one has messed w/ the alternator in some time, I suppose there could be an issue with the ignition switch.
Old Mar 16, 2011 | 09:08 AM
jagtoes's Avatar
Sounds like Swift is right on here. If you just replaced the alternator and the light was not on before the replacement then someone hooked it up wrong.
Old Mar 16, 2011 | 04:03 PM
cyclist01's Avatar
I disconnected the altenator and the light goes off..I hooked it up the way I took the old one off..one red wire to the plus output..one exciter wire and one ground wire..did the po have the altenator hooked up incorrectly?
Old Mar 16, 2011 | 04:48 PM
bubba240's Avatar
this might help with the connections.
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
greydiesel
Aug 16, 2009 05:18 PM
cmercon
Feb 2, 2009 02:15 AM
azalea
May 16, 2006 03:16 PM
