best buy says no aftermarket radio for my 93 240
Normal 0 I want to retrofit a aftermarket radio (JVC model KSFX12), with a newer one that has a faceplate input for an aux channels (ie. JVC KD PDR80) The web sites and the guy at best buy says nothing will fit the hole but that's based on the original volvo radio. Since someone's already crammed the JVC in there , intuitively it seems I should just slide the old one out and pop in a new one. What am I missing?
[IMG]local://upfiles/20160/870CE03B4B0B4686BA1E3DF1E35510C4.jpg[/IMG]
Installa
[/align][/align]
[/align]
[/align]
[/align]tion Details[/align][/align]Modified Fit - Requires Modification
Installation Details for your 1993 240 Series
Your vehicle is equipped with an upgraded factory sound system. We'll include a wiring harness (free with most stereos) that will bypass your factory amplifier so you can take advantage of your aftermarket stereo's extra power.
To install this product, you’ll have to modify your vehicle. [/b]
You will need to fabricate a mounting kit in order to install your new receiver.
http://www.crutchfield.com/p_105KDPD...0.html?tp=5684
give Crutchfield a call at 1-888-955-6000 and there folks will tell you what's has to be done
You are absolutely right! The previous owner already did the conversion and so you should be able to slide your new radio right in there. As long as it is a standard DIN size which it probably is...
Baldmccartney
Aug 4, 2015 07:39 AM
carol123
Oct 9, 2012 06:40 AM
amarygma
May 1, 2010 12:35 AM
850keeterbeata
Sep 25, 2009 04:33 PM
240, aftermaket, aftermarket, buy, crutchfield, faceplate, fits, florida, forum, installation, ksfx12, miami, radio, stereo, volov, volvo
