Blinkers went out
Old Apr 20, 2010 | 07:54 AM
avolvo's Avatar
Default Blinkers went out
bot this '90 240 DL sunday night...blinkers went out when i turned the bright lights on..now when i try to use the blinkers, the radio buzzes when its turned off..just tell me how or where i can find how to rewire it...
Old Apr 20, 2010 | 10:01 PM
swiftjustice44's Avatar
My best advice is to buy a Haynes or Chiltons manual...you'll be needing it.
Old Apr 22, 2010 | 08:12 AM
avolvo's Avatar
Default blinkers out
i will do it on payday
Old Apr 22, 2010 | 10:14 PM
Didn't mean it quite the way it sounded...but being a new to you car, you're going to need a basic manual to see what goes where. A word of caution...when checking fuse locations, believe what is on the back side of your fuse cover...the Haynes and Chilton manuals are generic and often the #5 fuse they are talking about is really the #3 on your car. Volvos are bad about ground wires...they have to be super tight.
Old May 3, 2010 | 03:39 AM
cameron_86_240's Avatar
My blinkers on my 240 used to go out before I got new fuses. Try running the lights through all the motions, turn the brights on, off, blinkers both ways, all lights on and off, and try turning a blinker on when the car is off, then starting it. worked for me. That's just a temp fix though, you need a new fuse.
Old May 15, 2010 | 10:37 PM
morrisamazon53's Avatar
Hi, you could check or replace fuses number 6, 9, 12, 13. Good Luck!
Ponzetti
May 29, 2015 04:10 PM
Platinum52
2001-2013 model year V70
12
Feb 25, 2013 01:37 PM
thetruthc32
Sep 27, 2007 01:36 AM
Pfeiffer124
Feb 23, 2006 02:11 PM
Alexander
Jun 28, 2005 10:33 PM
