Bosch MAF and Regina ATS
Old Oct 5, 2015 | 04:04 PM
dytha99's Avatar
Default Bosch MAF and Regina ATS
What is the difference in function between the Bosch mass air flow sensor and the Regina air temp sensor?
Old Oct 6, 2015 | 02:36 PM
um, they are *completely* different things. one measures air mass, eg, how much air is being sucked into the engine, while the other measures the inlet air temperature.
Regina also uses a manifold air PRESSURE sensor, which measures the manifold vacuum. Regina calculates the air mass from the air temp and manifold pressure, to figure out how much fuel to squirt in, while Bosch measures the air flow directly.
The Bosch MAF uses a heated nichrome wire across the intake air, and measures the current flow through this wire. more air cools the wire faster, this changes the wires resistance, which changes the current flow. unlike earlier mechanical air flow meters that used a moving flap, the hot wire automatically compensates for the thinner air at higher elevations.
Old Oct 6, 2015 | 04:45 PM
dytha99's Avatar
Thank you
92_240_sedan
Jan 14, 2013 01:26 PM
aether
Jan 24, 2012 12:30 AM
MNWILD
Jun 16, 2011 11:26 AM
Wheelyyy
Mar 5, 2007 08:50 PM
Lucky_Avalon
Engine & Internal
Jul 20, 2006 12:58 AM
