Brake bleeding tools
Old May 11, 2009 | 08:27 AM
daver80's Avatar
Default Brake bleeding tools
89 240- I’ve always used the old method of having an assistant pump the brakes, hose in a jar of fluid, hold and bleed in the correct sequence. You know the drill. Well I did that last night and it still seems kinda soft. What method does everyone use these days? Should I purchase some new equipment? Thanks! Dave
Old May 11, 2009 | 08:29 AM
adub96's Avatar
That should work fine. DId you happen to let the fluid get low in the reservoir when you were bleeding it?
Old May 11, 2009 | 08:33 AM
daver80's Avatar
No, I was pretty carefull to always keep it topped up. D
Old May 11, 2009 | 09:18 AM
adub96's Avatar
Well, then thinking about all the bleeders on the 240 I can think of like 8 maybe more. You did all 8? Did you tap the lines with something between bleeds to knock any bubble loose?
Old May 11, 2009 | 09:46 AM
daver80's Avatar
Default bleed
Yeah, I did all 8, never thought about tapping the lines. The book says to bleed the two lower (front) bleeders at the same time, does that mean two hoses, two wrenches? I just did lower then upper. Dave
rolling2
Oct 20, 2010 01:08 AM
snpklinefelter
Dec 22, 2009 06:26 AM
sasp11
May 20, 2009 08:40 PM
act1292
Nov 21, 2007 08:41 AM
Psaboic
Jun 1, 2006 01:14 AM
