Weird brake issue after bleeding
Old Jun 1, 2006 | 12:37 AM
Psaboic's Avatar
Default Weird brake issue after bleeding
Here is the deal. After replacing the rear brake pads and bleeding the brakes on the 850, I had a firm pedal with the car not running, so I started the car to try it. Pedal still nice and firm, but now the ABS and the TRACS light were on. I didn't mess with any connections, so it stumped me. I rechecked everything, and even made sure the fliud level was ok, which it was, but still had both lights on the dashoard lit up. Tried toggling the TRACS switch too, but it made no difference.
So, I turned the car off, waited a couple minutes and re-started it. Result.....no lights, and firm brake pedal. Road tested ok. Re-started 2 more times and no lights. Any idea what could have caused it or if I should worry about it??
Glenn
Old Jun 1, 2006 | 01:14 AM
Default RE: Weird brake issue after bleeding
Wait to see if it comes back on.
Sometimes they will act like this. The ABS finishes its test when you hit 15MPH.
swiftjustice44
Oct 25, 2012 06:32 AM
rolling2
Oct 20, 2010 01:08 AM
snpklinefelter
Dec 22, 2009 06:26 AM
sasp11
May 20, 2009 08:40 PM
act1292
Nov 21, 2007 08:41 AM
