Brake Light Failure
Old Apr 14, 2015 | 10:29 PM
j.cunningham's Avatar
Default Brake Light Failure
Hello Everyone!
I am always thankful for this forum. I can't tell you how many times you've helped me fix my 89, 240 sedan. Unfortunately, I have another problem.
All of my brake lights failed simultaneously. After reading a bunch of threads, I have checked and replaced the fuse, replaced any necessary bulbs, cleaned up the taillight circuit, checked and cleaned all the taillight grounds, and used a volt meter to check the power from the fuse box.
If I understand everything right, the power should run from the fuse box to the brake light switch to the red, round relay under the dash. Is this correct? At first, I thought the brake switch was bad, but then I noticed that I'm not even getting power to the brake switch.
Does that mean there's a problem between the fuse box and the switch? Or is it possible that I've misunderstood the power flow and the relay could be malfunctioning somehow?
Thanks for all your help! I look forward to hearing from you.
Jamie
Old Apr 14, 2015 | 11:15 PM
per the 1989 240 greenbook...
battery - red wire - positive terminal (on left fender well under hood)
positive terminal - red wire to input side of fuse 6 (which is connected to fuses 7-8-9-10 in the fuse panel)
fuse 7 - green-red wire to brake switch pin 1
brake switch pin 2 - blue-red wire to lamp failure sensor pin 9
lamp failure sensor pin 5 - blue-black wire to upper brake light.
lamp sensor pin 11 - yellow wire to right brake light
lamp sensor pin 10 - yellow-green wire to left brake light.
and thats all she wrote...
so... fuse 7, both sides, should be +volts at all times, and that green-red wire at the brake switch should be always-hot too. there is no relay in the circuit.
a note on the 240 fuse panel, each fuse has 3 spade lugs immediately to the right of it (behind the plastic kick panel). the RIGHT/REAR most spade lug is connected to the LEFT side of the fuse and is the input. the middle and left/frontmost spade lugs are both connected to the RIGHT side of the fuse and are the outputs. some fuses, ,like 6-10, have their inputs wired together inside the fuse panel.
Old Apr 15, 2015 | 10:23 PM
Pierce!
Thanks so much for the details! This is really helpful.
I started doing some digging around under the dash. I wanted to follow all the wires and make sure I checked everything for power again.
I'm a little confused by what I found. I'm hoping you guys can help me. I did my best to take pictures, though they didn't turn out great.
Alright, so if I followed everything correctly. The green/red wire leaves the fuse box and connects to a huge bundle that runs under the dash. As it nears the under part of the center console (close to the drivers feet) the green/red and the blue/red leave the bundle and run to this thing above the brake pedal. I couldn't get a great view of it, but as far as I can tell it doesn't seem to have a switch at the end of it that touches the brake pedal. Here's a picture of the top side (side closest to the driver):
https://drive.google.com/file/d/0Bxz...ew?usp=sharing
From there, a green/white wire runs to what I think is the brake switch. It sits just above the brake pedal, has a switch at the end that is compressed when the brakes are not in use, and there is a vacuum line attached to the top.
I tried to get some images of the wires and the switch:
https://drive.google.com/open?id=0Bx...lJV&authuser=0
From that switch the blue/red goes to another switch above the clutch and from there goes to a bundle of wires that connect to the cruise control module with a harness.
It was tough to access but I checked the power from the fuse box to the first connection I pictured. The green/red has power, but the green/white doesn't. I couldn't get the volt meter to touch the blue/red without some help. So, I'm not sure if it is hot or not.
Can anyone help me understand what I'm dealing with here?
Thanks
Jamie
Old Apr 15, 2015 | 10:43 PM
my 1989 wiring diagrams don't include the cruise control, but that vacuum switch thing sounds like its part of it. IIRC< the cruise on our 87 240 had a vacuum actuator near the pedals that actually pulled the gas pedal lever, rather than a cable to the throttle spool under the hood.
Old Oct 27, 2016 | 08:15 PM
Default Still Struggling With This
So, I still haven't figured this out yet.
Is it possible for by brake lights, and reverse lights to completely fail due to a faulty ground somewhere?
The tail lights work fine.
Thanks in advance for the help!
Old Oct 28, 2016 | 10:44 AM
cleanflametrap's Avatar
If you're sure the fuse is passing current, the most likely fault in your brake lights causing all of them to quit is not in the switch, but in the bulb failure warning sensor. You can reach that a lot easier than reaching the brake lamp switch, and get your meter or test light probe on the wire ends going into its big socket.
I'm not sure what year/model, but if 89 as referred to in pierce's response, the above is what yours will look like. Let us know for sure what model/year and we can tell you what to read where, as the wire colors had some changes year/year.
Edit: I see you clearly stated year and model, I just forgot it by the time I read on. The colors of the wires you need to measure:
Blue/red - 12V from brake light switch to BFWS.
Yel/gray - to Left Brake Lamp.
Yellow - to Right Brake Lamp.
Blue/black - to 3rd (high mounted) Brake Lamp.
With your foot on the brake pedal, check for voltage on these four points on the BFWS relay. That should tell you more about where the trouble is.
If you still think it might be the pedal switch, here are some tips getting to that thing:
240 Volvo: Replacing the Brake Light Switch
cheebster
May 8, 2014 04:31 PM
jasonthaynes
Dec 2, 2012 05:32 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
soulfulimpressions
Jul 31, 2008 07:07 PM
