Brake lights 740 wagon
Old Mar 3, 2016 | 08:34 PM
Richyrich514's Avatar
Default Rear fog lights and stop lamp 1986 740 wagon
edit:
Ok so let me clarify this again as it might help narrow it down.
Both top bulbs on my tail lights aka: rear fog lights and my center stop lamp(the light in the bottom center of the back glass) are all not working. The light on my cluster only comes on wen i press the brake pedal...
Checked fuses they seem ok just weird how they all went out same time
Old Mar 4, 2016 | 02:37 AM
all three brake lights have separate wires to the 'bulb out detector' in the main relay/fuse panel behind the ashtray.
however, they all go to the same ground, in the trunk, whihc I believe is under the left side floor panel, or maybe its under the covers for the 3rd row seat, look around just aft of the left rear wheel well.
Old Mar 4, 2016 | 10:04 AM
lev's Avatar
lev
If ALL brake lights are out, look at the relay for the "lights out", the big red double decker one... The brake light switch, distant second candidate.
Old Mar 4, 2016 | 10:34 AM
If i turn my lights on and i go to the back of my wagon the bottom red lights are on and when the brake is pressed those same bottom lights get brighter. I dont recall but do the top red lights need to be on as well and get brighter when brake is pressed? The light in te back glass does not work either.
Its weird how all this happened the same day.... It didnt happen while i was driving but i turned it off when i got home an once it restarted these lights stopped working.
Would this really be a groud issue for just these lights?
Also keep in mind that the warning light in my cluster only turns on when the brake pedal is pressed
Old Mar 4, 2016 | 01:09 PM
no, the brake lights on a 7/9 wagon or sedan are JUST the bottom segments, plus the high center light.
the top lights on a WAGON are the 'rear fog lamp', usually just the drivers side. on a sedan, its the inside lower light.
Old Mar 4, 2016 | 11:08 PM
Both top bulbs on my tail lights aka: rear fog lights and my center stop lamp are all not working. The light on my cluster only comes on wen i press the brake pedal...
Any input guys???
Old Mar 5, 2016 | 12:45 AM
its volt meter time, along with a copy of the wiring diagram.
the left rear fog should only come on with the foglamp switch. its a completely separate circuit.
wait, what year is your 740 ? they changed the lights somewhere around 89 or 90.
Old Mar 5, 2016 | 06:59 AM
Its a 1986
Old Mar 7, 2016 | 10:01 AM
Does the stop lamp and rear fogs share a fuse ???
Old Mar 8, 2016 | 06:32 AM
Turns out the center stop lamp bulb was burnt and i will wire the top bulbs to the brake lights.
Thanks guys
Old Mar 8, 2016 | 12:01 PM
tintintin's Avatar
Originally Posted by Richyrich514
...i will wire the top bulbs to the brake lights
I did this on mine and am very pleased with the improvement in brake light "performance." Those top lamps are always unlit and only light up when the brakes are on-- almost startling, and very much more noticeable to anyone behind.
88740gle
Nov 13, 2015 08:13 AM
aznyaz
Jan 9, 2015 02:38 PM
Scott V
2001-2013 model year V70
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
