Brakes failed, thought I was gonna die. Had kid in the car. Help please
Old Oct 13, 2011 | 10:16 PM
cichy1012's Avatar
Default Brakes failed, thought I was gonna die. Had kid in the car. Help please
Well I replaced my brake pads and rotors on the front, and coming back from the movies tonight I felt like I had no brakes right before I almost rear ended someone. I drove the last 2 miles home at about 10 miles per hour with the e-brake. I took a flash light to my wheel and realized all the padding is gone on both sides.
The calipers compressed fine when I installed them.So what gives?
Any help here what else I should look for?
Old Oct 14, 2011 | 08:07 AM
jagtoes's Avatar
You need to clarify this a little. When you said "all the padding is gone" do you mean that the brake pads are missing from the calipers. Are ALL the pads gone ? Did you pull the wheels and see if the pads have separated from the backing plate? Also are all of the retaining clips still in place or are the missing too? Did you check to see if you have brake fluid? Are the calipers leaking brake fluid. What did the brake peddle feel like when you stepped on the brakes. If the brakes worked well before you did the pad change then it appears that you did not do something correctly when you replaced the pads.
Old Oct 14, 2011 | 08:19 AM
volvoguy2323's Avatar
Banned
Next time that happens...pump your brakes...its a dual chamber master cylinder you should have braking power...anyway, yes please clarify.
Old Oct 14, 2011 | 10:34 AM
VileSmile's Avatar
If I had to guess, You mean you've actually lost the brake pads. That's really twisting my noodle.
A photo would help.
Old Jan 22, 2015 | 02:03 PM
What car are we talking about ??
Any chance you installed the pads backwards ?
Old Jan 22, 2015 | 04:57 PM
this is a 3 year old thread.
Old Jan 22, 2015 | 05:57 PM
No clue how I pulled this up. Last thing I knew I was searching through "New Posts". I'm so confused.
nmikmik
Aug 22, 2011 09:52 PM
hoffa61
Aug 17, 2010 11:59 PM
tomorrowmatters
Jul 9, 2010 09:15 PM
mhphoto
May 24, 2007 10:50 PM
