Burned speedometer 940
Old Jul 26, 2019 | 09:59 PM
kelseyd91's Avatar
Default Burned speedometer 940
Hello, I was just on a trip and during the long drive I looked down to see the speedometer was sitting at zero. Shortly there afterwards, the smell of burned electronics filled the cabin. When I got home I took apart the instrument cluster and resistor 2 (15 ohms) has burned. Here's the thing though, last year the same thing happened. I went to a junk yard and picked up an instrument cluster and swapped it and it was fine until now, so this is the second time this has happened. I've read that 91-92 model years had issues with leaky capacitors but mine are fine, it's just resistor 2 that has burned out.
Here is a picture of the board, I have removed the burned resistor.
I guess I need to repair it or find another one now. I did swap a 15 ohm resistor back on to the board but it still doesn't work so I don't know if it also blew out the ICs or other components as well..
Please help!
mjohansson2
Jul 3, 2018 12:17 PM
Lima850
May 24, 2016 04:12 PM
Atlantis
Apr 29, 2016 12:06 PM
Mndz
Jan 9, 2014 04:30 AM
WalterXI
Jul 4, 2011 09:56 AM
