240 instrument cluster conundrum....
Old Jun 23, 2018 | 03:46 PM
mjohansson2's Avatar
Default 240 instrument cluster conundrum....
Hello all I seem to have a serious problem with my old 1992 Volvo 240. First it all started with a NO instrument back lighting at all I had ordered new bulbs but found out the dealer ordered the wrong ones. So when I pulled out the cluster a job that I have done a dozen times on various 240's for some reason the "L" shaped connector broke off part of the circuit board on my speedometer cluster. I had a spare cluster out of a 90 240 so I swapped that. Speedometer did not work at all then. I noted on the top portion of my speedometer there are differences in the pin configuration. One has 3 pins the other has 4. So I did some soldering and swapping from the broken 4 pin to the ok 3 pin speedo. Now the car will not start. Like the fuel pump is not getting power. Major bummer. All the inst lights work, but the car will not start. So...I guess I have to find a replacement 4 pin small circut board for my original speedo, correct? is there a place I can order one as the local junk yards no longer have any 240 Volvo's at all!
Thanks and God bless.
Old Jun 23, 2018 | 07:36 PM
lev's Avatar
lev
I don't believe this car needs a speedometer or a cluster in order to start. Check your fuses, you might have blown one when you were dealing with the cluster...
Old Jun 23, 2018 | 08:47 PM
it needs the alternator light in the instrument cluster, or the alternator probably won't charge the battery...
Old Jun 24, 2018 | 02:21 PM
I checked the fuses and they all appear to be good. The car ran and drove just fine before I pulled the instrument cluster out and somehow broke that small piece of the PCB off. I never even touched anything under the hood either.
Old Jun 24, 2018 | 04:35 PM
lev's Avatar
lev
Well, you can start this car with no cluster in place. Yes, the alternator may not charge without the BAT light going ON then OFF, but apart from that the car should start with a charged battery present.
What does it do? Cranks? Or nothing?
Old Jun 24, 2018 | 04:57 PM
Well I didn't know the car would run without the inst cluster so I pulled it out and tried to start the car and it fired right up. So I then tried reverse logic hooking up each wire just to see what would happen. All went great until I hooked up the tach wire and then the car died imeaditaly. So I pulled it off and tried another contact point and the tach works and the car stayed running, the only wire I did not get hooked up was the ABS wire. I took it for a short test drive and the speedo is still dead. Bummer.....Any ideas there? Thank you for the tip about the car starting with the cluster removed.
Old Jun 25, 2018 | 12:49 AM
lev's Avatar
lev
240 are notorious for bad speedos. Could be the gear, or the capacitors, or... See Dave Barton's Volvo page, great info there. Davebarton.com
Old Jun 25, 2018 | 11:56 AM
Well it did work UNTIL I broke off that piece of the circuit board where the "L" shaped plug attached as stated I solder on the PCB board from the '90 model speedo. I think that is the problem. Anyway I do have good gears in it I took that apart and checked. I have had to do gear fixes on two other Volvo's I have had.
Old Jun 26, 2018 | 01:20 AM
lev's Avatar
lev
If it cannot be repaired, then you need a new CB...
Old Jun 26, 2018 | 01:23 AM
i would only replace the main circuit board on a speedo if it looked /identical/, otherwise, I would replace the whole speedo as a unit. Its been too long since I took a 240 dash apart, but on many cars, you can swap the speedometer out of the back of the instrument cluster.
Old Jul 1, 2018 | 08:11 PM
tony1963's Avatar
It will be fun finding a decent circuit board since these cars are, at a minimum, 25 years old now.
Old Jul 3, 2018 | 12:17 PM
xactorocker's Avatar
hey man If you are still having this problem I can check the Junk yards around and see if I can find one in good shape or one that hasn't already been taken out
DrHicks
Aug 13, 2011 10:30 PM
drcnnn
Mar 14, 2011 06:25 PM
belltv19
Feb 21, 2010 08:13 PM
chadman551
Dec 19, 2009 07:33 PM
scrapjacq
Dec 4, 2008 11:43 AM
