A/C Compressor Burnt Out
Old Dec 2, 2015 | 09:09 PM
thebuellster's Avatar
Default A/C Compressor Burnt Out
My a/c doesn't work anymore and my compressor has just burnt out. It smells like it burnt out at least, and a small amount of smoke comes from it if I drive for over 30 minutes. Can I replace it with a compressor that doesn't work but isn't burnt out? I looked into the kit from IPD to bypass it, but it doesn't fit my engine. Has anyone else had this problem? Is there anything else I could do?
Old Dec 3, 2015 | 06:41 AM
act1292's Avatar
Yes, you can use a non-functioning unit as an idler pulley. I think I may need to do the same as mine is starting to make noise. I have considered disassembling it and re-lubricating the bearings as it might extend the life a little longer. My AC hasn't been functional in years.
Old Dec 3, 2015 | 04:19 PM
thebuelister: if you disconnect the wire to the compressor/clutch (or unplug the pressurestat at the a/c reciever/dryer), does the pulley freewheel ? If the clutch is frozen, then you'll need to find another compressor with a good clutch, and swap them... if the new compressor is non-op just leave the Ac control wire disconnected and taped off.
Porkchop99
Jan 30, 2011 06:05 PM
kylebooth
Nov 3, 2009 03:59 PM
Squiggy
Feb 21, 2009 02:10 PM
Cambridge Volvo
Apr 15, 2008 02:09 PM
01V70T5
Jan 19, 2006 12:42 AM
