Caligo Wheels/Tires on 1991 240 & 25mm Spacers
Old Mar 8, 2019 | 11:58 PM
norcal240's Avatar
Default Caligo Wheels/Tires on 1991 240 & 25mm Spacers
All - I'm assuming that a set of Caligo (16) wheels (https://sfbay.craigslist.org/nby/wto...824849573.html) will fit my 240 as long as I invest in the 25mm spacers - correct?
If they should fit, anyone know the difference between the two different types of spacers offered on IPD?
https://www.ipdusa.com/products/1152...waAhv1EALw_wcB
vs.
https://www.ipdusa.com/products/5750...60-780-940-960
They look to be made out of different material - perhaps one CNC vs. another cast? Anyone know the difference between these two and the reason for $50 difference?
Anyone have any opinions, insight, or experience with this potential pairing?
Thanks!
Anthony
Old Mar 9, 2019 | 04:57 PM
those both look machined to me.... the more expensive ones are H&R, from Germany, while the cheaper ones are IPD house brand. AFAIK they are both anodized aluminum alloy.
putting 16" wheels on a 240 will result in a rather busy harsh ride on rougher pavement. your tire inflation pressures will be much more critical with a /55 tire vs the OEM /75 tires. your wheel alignment will be more critical too, and if your suspension bushings are tired, you'll feel it even more with the /55 16" wheels.
Chautauquasun
Oct 23, 2017 09:16 PM
jpsepp123
Dec 16, 2015 06:56 PM
tdrendel
Sep 28, 2012 09:26 PM
IRMB
Jun 27, 2012 04:38 AM
ss~zoso~ss
Mar 15, 2007 11:10 AM
