740 EVAP Canister replacement -- simple question!
Old Mar 10, 2019 | 09:48 AM
murfboroman's Avatar
Default 740 EVAP Canister replacement -- simple question!
Hi -- got a 1991 740. Can't pass emissions due to high hydrocarbons. I found a broken vacuum line, so I'm going to replace that regardless, but in the meantime I'm looking at the EVAP canister. I can see vacuum lines connecting to the top of it, but while poking around there's a large rubber hose coming off the bottom that is open ended. I'm just looking for -- if anyone has it -- a breakdown of the "hookup" for this EVAP canister. Is that open-ended (large) rubber hose on the bottom some kind of "drain"? Surely not? What does it/what is it supposed to "connect" to? Thanks in advance.
Old Mar 10, 2019 | 10:50 AM
lev's Avatar
lev
It is a drain.
Old Mar 10, 2019 | 02:03 PM
the evap canister should have zero impact on tailpipe emissions, its all about vapor capture and recovery from the gas tank. around here, it will be visually inspected, and a vacuum tester will be attached to the gas filler pipe, where they pump down the tank, then ensure it holds a mild vacuum for 5 minutes or something.
high HC typically means your engine is running too rich ... some things to check...
  • vacuum leaks downstream from the MAF
  • tired ignition system components (replace cap, rotor, protector disc, wires, plugs)
  • worn out OX sensor
  • worn out catalytic converter
91shelby
Feb 7, 2022 10:52 AM
97-850Wagen
Apr 10, 2016 07:30 PM
Skua
Feb 13, 2013 05:10 PM
S5990
Sep 28, 2009 03:57 PM
jmalkames
Apr 16, 2008 11:49 PM
