Can a 1983 b21ft turbo bolt up to a 1984 b230f non turbo?
Old Nov 18, 2023 | 02:05 PM
Sulaymaan's Avatar
Default Can a 1983 b21ft turbo bolt up to a 1984 b230f non turbo?
I have a 84 b230f non turbo, I also just got a wagon with the b21ft with a turbo original setup, the b21 needs a new rod but I was wondering if I can just bolt the turbo up to my b230, the b21 is mechanical fuel injected (kjet) where as the b230f is electronically fuel injected, I was planning on swapping the b2ft into my sedan that has a b230f
Old Nov 18, 2023 | 05:41 PM
Originally Posted by Sulaymaan
84 b230f non turbo, I was wondering if I can just bolt the turbo up to my b230,
Certainly the manifold will bolt up - but the turbo block has a hole in the side of it for the turbo oil return drain tube - if your block has a cap/freeze plug in that predrilled hole - now you have somewhere for the oil in the turbo to go.
Find a 740/940 turbo in a junkyard and examine how it is done with EFI.
Old Nov 18, 2023 | 11:24 PM
Sulaymaan's Avatar
ok thanks
DiagFx
Aug 9, 2013 11:46 AM
jujudude
Jul 30, 2012 07:59 AM
Rideordie13
Nov 24, 2011 03:18 PM
someday70R
Sep 18, 2008 05:40 PM
MattB850in
Apr 10, 2007 07:55 PM
