Can someone explain tie rods to me?
Tie rods are part of the steering of the car.
There is inner tie rods which are from the rack out. The outer tie rods connect to the inners then connect to the Hub assembly.
There is a possibility it could cause a very dangerous situation if they are really bad.
I mean like they could come apart and cause an accident.
spot on tech. To the OP if you plan on doing your own tie rods, when your done your going to need a wheel alignment. Unless you mark the outer tie rod ends where you stopped pulling them out.. I usually use white out, then thread them back on. You will also need a tie rod puller
1995Volvo850
Aug 7, 2013 08:53 PM
bimmerd00d
Mar 18, 2009 06:55 PM
