Can someone tell me what this is called?
Old Apr 22, 2005 | 05:57 PM
dece207's Avatar
Default Can someone tell me what this is called?
I have an intermittent air flow issue from my vents......see my post with the related subject heading........plenty of air blows from vents at idle, none under acceleration....I noticed this cracked hose (see photo) under the hood which I believe is the cause. Any opinions? And can someone tell me exactly what this is called so I can research the part needed?
Thanks forum!
Dave DeCoste
[IMG]local://upfiles/1584/CFDCD9302FB54631B7A29966618A26EB.jpg[/IMG]
Old Apr 22, 2005 | 06:08 PM
dece207's Avatar
Default RE: Can someone tell me what this is called?
Here is another photo of part.
Thanks again.
[IMG]local://upfiles/1584/08994E25FBA342B381E68C1FAA0C69D5.jpg[/IMG]
Old Apr 22, 2005 | 07:11 PM
Carbuff's Avatar
Dave,
My '94 Wagon doesn't have those pieces!
But from the looks of it, you could wrap the split hose in Duct Tape and take a test-drive, just to see if it makes a difference.
(I wouldn't leave the duct tape on it long, though, too close to the exhaust header...)
Atwell Haines
'94 940 wagon
NJ
Old Apr 22, 2005 | 07:41 PM
That is part of the EGR system.That shouldn't be causing the problem you are having.
I forget exactly what the name is.Volvo is good for having about 5 names fro the same thing.
Old Apr 26, 2005 | 03:40 AM
will/bill's Avatar
pair or pulse air injection hose for the emmission air injection system
Old Apr 26, 2005 | 03:46 AM
will/bill's Avatar
the hose you point to will not cause the vacuum problem you are having look at the air control valves inside the car on the heater a/c box their are two way vacuum control valves or the vacuum reserve cell note: under accelleration the car has low vacuum (open throttle ) and this can cause the blend door to switch position.
k2xblade
Jul 24, 2014 11:47 AM
yungprofit703
Mar 23, 2011 08:52 PM
DRKSIDExrs
Aug 28, 2009 07:59 PM
Moparman
May 3, 2008 06:42 PM
Volvo850GuyInMa
Nov 2, 2007 04:12 AM
