Changing brake pads
Nope...pretty straight forward. My advice is to always do one wheel at a time. That way you have the opposite side to use as reference. Also, Volvo liked to mix up brands of calipers which will affect the type of brake pads purchased. Some were ATE, some Girling...best to pull a wheel and determine that before buying the pads.
If you're replacing rotors be prepared for an interrogation by your parts guy! On my 740 there was 2 different venting options and 3 different rotor diameters. Just goes to show you how little parts guys actually know...I usually go in knowing more about what I'm looking for than the person behind the counter. Owning a european car is like owning a ford...every part has 20 different options for size/style.
dpm2340
09-21-2006 08:33 PM
