need help- changing rear brake pads '07 S80
Old Feb 16, 2009 | 08:37 PM
m1964's Avatar
Default need help- changing rear brake pads '07 S80
I have 2005 XC90 and 2008 Land rover LR2 -land rover uses the same brakes as 2007-2008 Volvo S80 3.2L.
A few months ago I changed front brakes on Land Rover and 2-3 months later master cylinder went bad -I was told that I should have opened bleeder screws before pushing pistons back into the calipers.
Now I want to change rear pads and need advise:
1. Do I need to clamp the brake hose before opening the bleeders?
2. Is there a "special" tool required to push pistons back into the calipers?
Since there is only 1-2 mm left on the pads, I cannot wait too long -pleeease, HELP!
thanks a lot
Old Feb 16, 2009 | 09:06 PM
No need to open the bleeder. A pair of pliers should work to push it back.
Old Feb 16, 2009 | 10:03 PM
m1964's Avatar
tech,
thank you for quick reply
- I was told that (when changing the front pads) by pushing back old brake fluid I destroyed seals in the M. cylinder... Is that true?
thanks again
Old Feb 17, 2009 | 06:17 PM
I have heard on some car lines it can. But on Volvo it does not.
Old Feb 24, 2009 | 08:30 PM
m1964's Avatar
tech,
again, thanks for your help
Old Feb 24, 2009 | 08:33 PM
No problem anytime.
Old Feb 25, 2009 | 06:05 AM
jlewisinsyr's Avatar
I have to wonder, how many miles do you have on your car that you need to change the rear pads already...
Rears go a lot longer then fronts.
Old Feb 25, 2009 | 05:07 PM
diehardgator1's Avatar
Tech I have 125,000 miles on my car and as far as I know have the same rotors and calipers. Never had to turn them and they have never warped on me. Do you think the rotors and calipers need changing?
Old Feb 25, 2009 | 08:09 PM
I doubt the calipers need replacing.
The rotors can be measured to see how thin they are.
pchow138
Nov 3, 2011 09:42 PM
angrylittlefisherman
Apr 11, 2011 12:29 PM
fortmemphis
Sep 20, 2010 08:56 PM
JohnTheodore
Apr 28, 2008 12:35 PM
dpm2340
Sep 21, 2006 08:33 PM
