Changing out the clutch Pressure plate?
Old Nov 1, 2007 | 02:39 AM
iamnickcarter's Avatar
Default Changing out the clutch Pressure plate?
I just got a clutch kit for my '76 242
After going through hell dropping the tranny, I cleaned it out, scraped off some dirt and unbolted the old clutch.
hooray asbestos!
Now, when I installed the new clutch after replacing the pilot bearing and looking at the flywheel...I don't know how much to tighten down the pressure plate. Should I just tighten it down really flippin hard? Is the clutch plate supposed to be in contact with the pressure plate and flywheel constantly?
I have no idea, first time doing this and it's been all too easy.
Old Nov 2, 2007 | 02:28 PM
VolvoDriver's Avatar
Default RE: Changing out the clutch Pressure plate?
it is easy. the clutch disc will be held in by the pressure plate, be sure to use an alignment tool to center the dics with the plate and crank. tighten the plate boltsto 18ft./lb. of torque force.
Old Nov 3, 2007 | 03:13 AM
I tightened mine to 45ft/lbs
is that ok? I'm not dropping the tranny again.
oops.
gentlejax2
Jun 18, 2012 03:19 PM
850tony
May 26, 2009 06:30 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
