clutch pedal force/pressure
Old May 25, 2009 | 10:14 PM
850tony's Avatar
Default clutch pedal force/pressure
hey-
so i just recently purchased my first manual volvo (needed throw out bearing so i got it for cheap ) and i put in a new clutch right away to.
everything bled out fine and stuff. and the clutch fork has very good movement. but the clutch pedal is really soft... is this just normal for volvo's?
like i said, i havnt even pushed thus clutch in on a volvo untill i got this one.
i replaced the slave cylinder also.
Old May 25, 2009 | 10:18 PM
Yes they are always pretty soft.
Old May 25, 2009 | 10:20 PM
850tony's Avatar
ok that makes me feel better i guess to know that i didnt bleed something wrong or anything (or that my master is bad).
im used to a very stiff clutch in my other two cars, so its a big change for me. i do personally love how smooth the trans is tho
Old May 25, 2009 | 10:22 PM
Everytime I get into one to move it I pretty much stall it because it is so soft.
I am used to a cable Mustang King Cobra clutch.(Almost needs 2 feet to use it)
The hydraulic ones tend to be on the soft side.
Old May 25, 2009 | 10:26 PM
850tony's Avatar
haha isnt that ironic, im used to the cable clutch in my 69 stang, or the clutch in my eclipse (6 puck act clutch)
Old May 25, 2009 | 10:32 PM
Very Ironic!!! LOL
Although right now the stang is burried in the garage.
Old May 25, 2009 | 10:38 PM
850tony's Avatar
ya.... i have only gotten mine out once this summer season. needs to get out more!
Old May 25, 2009 | 10:40 PM
Mine is waiting for me to pull the motor to swap that motor to a HO motor.(Long story)
Old May 25, 2009 | 10:42 PM
850tony's Avatar
always is when you mention motor and mustang haha.
i just finished restoration on mine (5 year process). its a whimpy 289 coupe with a 3spd, great car for the weekends though!
Old May 26, 2009 | 06:30 PM
Yes it is I thought I spun a bearing in the old motor and pulled it and installed a Non Ho motor. But then found out the balance had spun and was 7 degrees off giving spark knock.
But I have all the parts to convert the motor to a Ho motor and need to pull it and convert it. Then get an aftermarket Dist. The pick up in both of mine are bad.
rspi
Aug 25, 2010 06:15 AM
DJ420
Aug 23, 2010 08:24 PM
trev0006
May 17, 2010 01:14 PM
ludeless
Feb 1, 2008 06:41 PM
karvr
Nov 24, 2006 10:06 AM
