Charging problems...1993 240
Old Oct 27, 2008 | 01:24 PM
briang232000's Avatar
Default Charging problems...1993 240
I own a 1993 Volvo 240. I removed my alternator and tested it at three different parts houses, and it passed all three tests. However, once I put it back on the car and drove it back to those parts houses (with a brand new battery), the handheld tests said that the alternator was not working...any suggestions? Thanks.
Old Oct 27, 2008 | 04:28 PM
blue goose's Avatar
Default RE: Charging problems...1993 240
Make sure the skinny red wire has a good connection at the back of the alt. It carries the excitation voltage for the field windings.
Does the battery/charge light come on while you crank the engine?
Old Oct 27, 2008 | 07:26 PM
Bluegoose...
Thanks for your quick response. Concerning the light-I had found a previous post where another person was experiencing the same problem that I am having. Someone suggested that may have been the problem, but I checked the light and it is on whenever I turn the key to "on".
As far as checking the wire, are you talking about the wire that goes directly into the block? If so, it is secure. My brother is going to come over with a voltmeter tomorrow and check some other wires. I'm thinking that maybe there is a short somewhere between the alternator and the battery.
Would I be experiencing this problem if the voltage regulator is bad?
kapkloss
Feb 11, 2013 05:39 PM
jws
Dec 30, 2011 08:09 PM
jeremygreg
Apr 13, 2010 08:57 AM
briang232000
Oct 27, 2008 01:26 PM
ddorshimer
Aug 26, 2008 01:54 AM
