87 244 charging problems
Old Mar 27, 2010 | 05:20 PM
jeremygreg's Avatar
Default 87 244 charging problems
Hey guys Ive been messing with this for a long time.
I recently replaced my alternator and battery because i was having charging problems. everything seemed fine until today when my car wouldn't start. I got it jumped and running but the radio and lights started going out gradually so i went to the auto parts store and disconnected my battery while my car was running and it kept running.. I got my battery checked and it was fine, just needed to be charged. Then i had the alternator tested after i reinstalled the battery and it showed that it was not charging.
i dont know much about engine wiring but im assuming that i have a bad connection between my alternator and my battery. Any ideas on how i can go about trying to find it?
Old Mar 27, 2010 | 07:09 PM
pcarsrule's Avatar
Grounding strap going bad/open?
Old Mar 28, 2010 | 10:52 AM
tedv's Avatar
Is the Charge Light on the dash functional, ON while key is at II, OFF when car is running?
Old Mar 28, 2010 | 01:17 PM
jeremygreg's Avatar
No, the charge light hasnt worked since I've had the car.
Old Mar 28, 2010 | 08:11 PM
tedv's Avatar
Your alternator will not charge unless the ALT light on the dash is functional. To test this, run a wire between the battery + terminal and the male connector on the back of the alternator, after unplugging it from the female plug, the wire closest to the drive's side fender wall. Hook some type of 12V bulb in between-the light will stay on until the car starts, then the bulb will go out, and the alt should kick in... Use a multi meter to check.
Old Apr 13, 2010 | 08:57 AM
jeremygreg's Avatar
Thanks for the replies.. Actually, my alternator bracket had broken some time before and stretched out my belt... easy fix.
kapkloss
Feb 11, 2013 05:39 PM
cyclist01
Feb 27, 2011 06:03 PM
briang232000
Oct 27, 2008 07:26 PM
briang232000
Oct 27, 2008 01:26 PM
ddorshimer
Aug 26, 2008 01:54 AM
