compatible transmissions?
Old Sep 20, 2006 | 10:48 PM
alexm963's Avatar
Default compatible transmissions?
I have a 1981 264, but it has the B21F engine in it so I thought this would be the place to go. The tranny is starting to slip on it. It's my fault, I was doing burnouts with it. Any ways its an automatic and I don't know what tranny it has. My local junkyard doesnt have and automatic 240s so I was wondering if any of the 740 or 840 trannys are compatible with mine. Or if you think it might just need a new flywheel or clutch? It seems to shift fine when it shifts, it just doesnt shift automatically all the time, sometimes I can get it to when i start going in first then shift to second then drive, but sometimes it will stay in first or second up to 6000 rpm before i let off and fiddle with the shifter. So anyone that can help that would be great.
Old Sep 21, 2006 | 08:36 PM
Default RE: compatible transmissions?
Check the kick down cable under the throttle cable and see if it is seized.
The 740 Trans should work fine.
reading1
Sep 7, 2009 06:13 AM
Mary2214
Nov 5, 2007 11:14 PM
michpc
Aug 27, 2007 06:21 PM
RedTurbo850
Oct 28, 2006 06:07 PM
someguy2112
Jul 22, 2006 01:49 PM
