Coolant Cap
Old Sep 17, 2005 | 11:51 AM
Carbuff's Avatar
Default Coolant Cap
Should the coolant cap on the plastic bottle hold pressure on a cold engine?
When I open the cap, (engine sitting overnight) I get a big WHOOSH and the coolant level jumps up an inch in the bottle.
I always thought the system should allow air back into the coooling system as the engine cools.
Old Sep 17, 2005 | 12:00 PM
Default RE: Coolant Cap
On a sealed system yes it will hold pressure even after sitting all night.
Yes you have a sealed system.And it will hold pressure.
Old Sep 20, 2005 | 12:06 AM
Carbuff's Avatar
So,,,
How does a shadetree mechanic like me make sure there is not too much air in the system?
(idle the engine with the cap off?)
Old Sep 20, 2005 | 01:36 AM
That doesn't always work the proper pressure can't be met and it will overflow.
The air will bleed out by itself.
Old Sep 20, 2005 | 02:28 AM
Qamar's Avatar
Good to hear that the air will bleed out from the over flow plastic bottle. In my previous BMW 325i, it was a bid problem to bleed out the air from the system. Sometimes we had to bleed it for days....
Old Sep 20, 2005 | 09:12 AM
Carbuff's Avatar
ORIGINAL: tech
Where?
(I sure am inquisitive, huh?)
Old Sep 20, 2005 | 08:45 PM
It will get out don't worry.
There is not a problem with any of the 4 cylinder cars with bleeding the system.
hyoki
Jan 10, 2012 07:26 AM
alphaperez
Nov 11, 2011 10:17 AM
1996850turbo
May 4, 2011 08:11 PM
kturner3
Nov 7, 2008 07:17 PM
jimatqsi
Aug 26, 2007 01:13 PM
