Crankshaft Pulley Holder Tool
I am about to change the timing belt on my '93 940 turbo wagon. It's an automatic transmission, so I need something to lock the crankshaft in place while I loosen the nut. Volvo makes a tool for this (#9995284). But I try to avoid paying $50 for a tool that I will use only once or twice. Has anyone engineered another way to lock the crankshaft - and care to share your method? Or is anyone willing to share their Volvo tool with me (I'm in central PA)? I would pay for shipping both ways. Thanks.
When I first considered doing it I had the same concern. But after removing the fan and radiator shroud the 1/2 drive gun with a normal socket just fit. I cover the back of the radiator with a piece of cardboard and it works out. All I need is to just break it loose and then can do the rest by hand. I recall and it was a long time ago that I did do the blip method where I disconnected the coil wire and using a breaker bar with a socket wedged it and hit the starter . Did the job . Either way was OK. I don't know the space in the 240 but the 740 had enough.
I realize this is not a new thread, but I'm changing the timing belt on a 940. I bought the crankshaft holding tool, but at TDC, the holes on the crankshaft pulley don't line up correctly with the tool to slip the other end in place on the tensioner bolt. If I moved the crankshaft pulley several degrees one way of the other, I could get the tool to fit. As long as I line up the crankshaft pulley back to TDC after the bolt is loosened (but not removed), won't that work?
I'll try that. I feel like I already rotated the crankshaft once because the mark wasn't lining up on the top either, but I could be mistaken. I did get somewhat distracted by a spark plug that did not want to come out. I'm hoping like hell I can figure out how to get that one back in without too much issue.
You should worry if it's a interference engine - (like all later Volvos) but it's not.
'It's the "correct positions" part I don't quite get. Correct as determined by lining up the marks on the belt with the corresponding marks on the sprockets?
![](https://cimg3.ibsrv.net/gimg/volvoforums.com-vbulletin/861x298/94tbelt_5eaa540de1df6ca3a03cd706310cc34bb936b462.jpg)
So I installed the belt, but the mark on the plastic backing of the timing cover for aligning the intermediate pulley did not align with the mark on the belt, but aligning the mark on the belt with the mark on that pulley did result in the distributor being at the #1 position, so that seemed right to me.
#17
#18
