Darn Breaks 740
Old Mar 13, 2006 | 03:22 PM
colgate41's Avatar
Default Darn Breaks 740
Hey all its me again. As of late my breaks have been squeeking more than normal and it is comming from the front becuase i just had the back breaks and rotors done in Dec. So before i went off to buy some new pads etc, i took off both front wheels and examined the pads first. I saw that the front pads on the outside looked like they have a lot more life left on them. I couldent see the back side pads really well due to the caliper. Now i was wondering if there are any cases of the inside pads wearing much more than the outside pads, and could that be my problem? When i start to apply the breaks on the park way or at a high speed i get this terrable jerking of the wheel, but if i push down all the way this jerking goes away and it is smooth stopping. Any help? Thanks again!
Old Mar 13, 2006 | 04:37 PM
ZIGZAG's Avatar
Default RE: Darn Breaks 740
You might want to have you master cylinder checked.
Old Mar 13, 2006 | 09:53 PM
The sliders on the caliper might not be sliding freely.
Old Mar 13, 2006 | 11:10 PM
colgate41's Avatar
Ah ok Tech. What do the sliders look like so i can take a look. I forgot to mention that the squeeking is intermedit. I suspect myself warped roters, but i dont want to fix things that are not broken.
Old Mar 14, 2006 | 12:27 AM
The sliders are Where the bolt goes through the caliper. Also the top might just have a pin on the Bracket side and a hole on the caliper.
Are they Volvo pads?
Old Mar 14, 2006 | 12:42 AM
colgate41's Avatar
Tech i am not sure as i havent removed the calipers since i bought the car in August. I have read that non-volvo pads tend to squeek more so that orginal volvo pads. Thanks for all the help.
Old Mar 14, 2006 | 01:01 AM
Let me know how it goes after you check it.
Yes aftermarket Squeel ALOT more than Volvo pads.
Trace
Jun 2, 2009 09:46 AM
jks2
Nov 22, 2008 10:17 AM
Vdubchandler
Nov 29, 2007 09:01 PM
jks2
Aug 26, 2007 01:01 PM
mdhughes
Jun 8, 2006 02:06 AM
