Darn Oil light.. Please help
yes it has enough oil, doesn't even leak oil. From what I have heard the oil system is sensitive to any air leaks, so any cracks in some of the air hoses could cause the problem. I just wanted to verify that the info is true.
so to answer your question everything is up to code and full
the symptoms you describe indicate low oil pressure which can be due to worn out oil pump or plain worn out engine. how many miles on the car? i'd start by addressing the oil/filter issues and go from there.
