dashboard light on and off
Im having the same issue. Is this an easy fix DIY? Do you know of a thread that explains this? Thanks
If you mean the warning lights are all flashing that's often a bad ignition switch. Not the part you see where the key fits; behind it is an electrical portion tha when it is worn out does precisely what you describe. Alternately, there could be a bad main power ground to the cluster.
97-850Wagen
09-10-2013 10:40 AM
mcaanda
04-27-2010 01:00 PM
