Door Panels -- How are they held up?
Old Aug 20, 2006 | 12:19 PM
ko_kidd's Avatar
Default Door Panels -- How are they held up?
How are these things held on?
My right rear door panel is loose at the top left. (Like above the speaker)
I was comparing it to the left rear door panel and I can't seem to find anything that's missing from the right side. Is it simply that horizontal metal bar around the window?
...And I can't unlock the door from the inside--I have to do it with a key or with the drivers-side latch. Anyone know what's goin on there?
Old Aug 20, 2006 | 12:31 PM
Default RE: Door Panels -- How are they held up?
The Rear door panel should just latch on top.
The front one you will have to remove and inspect the door lock setup.
Old Aug 20, 2006 | 07:39 PM
ko_kidd's Avatar
But by "latch on" I mean where? I'm not sure if a clip is bent or broken or whatever but the thing is lose and I can't figure out *how* it latches on.
Old Aug 20, 2006 | 07:56 PM
The top of the door panel should wrap around and slide into the top of the Door.
Old Aug 20, 2006 | 08:50 PM
ko_kidd's Avatar
I circled the part I assume you're talking about in red:
(Not my interior--just a pic I found)
The metal bar under that rubber seperator is loose and I haven't figured out why or how to tighten it back up.
Old Aug 20, 2006 | 10:02 PM
Remove the Other side rear one to look at it and see what is missing compaired to the other one.
volvogltturbo
Jan 17, 2008 01:16 PM
Lab_Rodent
Nov 3, 2007 01:12 AM
DNC
Sep 21, 2007 12:20 PM
daver80
May 8, 2007 04:35 PM
SpecterV70
Jun 4, 2006 03:07 PM
