Door sill trim removal tips?
Old Nov 20, 2011 | 06:00 PM
Sambar Stag's Avatar
Default Door sill trim removal tips?
Hi. A search of this forum didn't reveal anything; does anyone out there know how to remove the black plastic molding on the bottom of the door opening on a 240? I'm trying to replace the seat belts in this car and have gotten the B pillar trim piece along with the top belt bolt removed; it appears that the door sills have to have be at least part way removed in order to slide that trim piece up to remove it and expose the retractors.
I don't want to damage these pieces; does the sill pull out from the body, or perhaps slide up and then out? Thanks,Bob
Old Nov 21, 2011 | 09:57 PM
swiftjustice44's Avatar
Bob, they lift straight up. Held on by metal clips to the soon to be exposed pinch weld. They are pretty darn sturdy; I've never broken one. Start at one end and pry up with a wide screwdriver. Once it's started just give a yank straight up.
Old Nov 22, 2011 | 11:14 AM
Default Door sills
Thanks so much, Swiftjustice. I just knew someone here would have run into the same issue. I appreciate it.
greg1976
May 8, 2015 03:51 PM
14XC60
Jun 6, 2014 07:36 PM
rspi
Apr 4, 2013 10:59 AM
jamesybutler
Feb 2, 2011 06:13 AM
azmark
Oct 19, 2005 08:57 PM
