ECM
Old Jun 8, 2006 | 10:41 AM
Snooky's Avatar
Default ECM
I have a 90 Volvo 740GLE with the B234F engine. It is dumping fuel. I changed all the logical things without help. Took it to Volvo, and they said all they could do was start changing parts. I believe the computer is causing the problem. Any ideas where I can get a new or used computer for my Volvo??? Thanks.... Automatic tranny...
Old Jun 8, 2006 | 03:46 PM
cbevis's Avatar
Default RE: ECM
Do you mean dumping fuel litterally or just that it's burning fuel too fast?
Old Jun 8, 2006 | 08:51 PM
Default RE: ECM
Junk Yard but make sure all the Numbers match.
Also so you replaced the Mass flow,o2 sensor,Coolant temp sensor,?
Old Jun 9, 2006 | 09:57 AM
Snooky's Avatar
Default RE: ECM
Running very very rich. I can crank it up, shut it off, pull the plugs and they will be covered with soot. I checked the sensors, but did not change them. Would the sensors cause it to run that excessively rich? I changed the plugs, wires, cap, rotor, fuel pressure regulator, and tested the sensors. It just seems like something is telling it too dump fuel. It does it cold or hot, doesn't matter. I was thinking the O2 shouldn't have an effect on the engine when it is cold. Just trying to narrow the problem down, and getting kind of frustrated...
Old Jun 9, 2006 | 09:51 PM
Default RE: ECM
The o2 will have an affect when cold.
My guess would be either o2 or mass flow sensor.
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
Kara425
May 10, 2005 09:31 PM
Kara425
May 10, 2005 08:52 PM
NHV70
Apr 1, 2004 11:55 AM
