ECU codes - 3.3.2 TPS (throttle closed); 3.3.2 TPS (off idle/part throttle)
Old Jan 23, 2018 | 11:58 AM
ericjs61's Avatar
Default ECU codes - 3.3.2 TPS (throttle closed); 3.3.2 TPS (off idle/part throttle)
According to the Testing of the TPS:
Activate the following sensors. If the LED diagnostic code shown (note: this is not a fault code) is present then the sensor or component is OK:
  • TPS OK in full load position (when throttle is moved from full load) 3-3-3
  • TPS OK in idle position (when throttle is moved from idle) 3-3-2
When I run this test I get:
TPS in full load position (when throttle is moved from full load) 3-3-2
TPS in idle position (when throttle is moved from idle) 3-3-2
I am wondering if this means the TPS needs to be adjusted?
Old Jan 23, 2018 | 05:16 PM
the TPS is a simple microswitch closure, one for idle, the other for full throttle enrichment.
mphilleo
Feb 14, 2016 08:50 PM
Teamsobaco
Apr 4, 2013 01:52 PM
Shaun Oriold1
Mar 16, 2008 06:54 AM
mynauticaldog
Oct 11, 2007 08:45 AM
DENNISVHANK
Oct 22, 2005 02:49 PM
