Electricity, E-Lec-tricity.
Old Aug 18, 2006 | 05:06 PM
VolvoDriver's Avatar
Default Electricity, E-Lec-tricity.
Hello Fellow Volvo drivers,
1991 740T Sedan:
For a good while now I have been in knowledge of all which surrounds me, I am talking about my Volvo. Specifically, an item I noticed in my tank is the ventilation fan controls. Power level 4 is non-op., one, two, three, and five operate, but when the *** is turned to power level four, the fans cease. I only can imagine electrical issues.
Prior to which I encountered an issue the Volvo would cut out and/or stall when the vents were selected to the feet or lower cabin. After I took it to a man to get it checked with no real confirmation upon the issue, I later noticed this fourth fan power level issue.
-Shrug- Fault wiring? I do not know. Of that. What do you think?
thanks.
Old Aug 18, 2006 | 08:45 PM
Default RE: Electricity, E-Lec-tricity.
Yes possibly wiring or some of the resistors the 4 speed runs through but is not dropped down.
Check for Voltage at the motor on 4 and back track.
Old Aug 18, 2006 | 09:36 PM
thanks for the reply...
hmm, interesting. So, i imagine i will be taking dash and a whole other bunch of from cabin components off/apart in order to perform these tests upon voltage? An ohmmeter is required i also imagine. would i refer to a repair book for proper voltage readouts and/or resistor properties? ayeyieyie.
Old Aug 18, 2006 | 09:47 PM
You should only have to drop the lower Dash panel to gain access to the componants.
Sorry I don't have a book though.
Old Sep 6, 2006 | 03:23 PM
computorsarenoteasy's Avatar
my heater motor just quit for no reason no squeaking like usual before going just stopped .took out the switch and tried hot wiring, no good is there a reostat? have seen that before.fuses are good.if there is a reostat where is it located?
Old Sep 6, 2006 | 08:41 PM
There is a resistor pack located by the Blower motor. It is screwed into the Air box.
huqqis
2001-2013 model year V70
Mar 18, 2013 12:27 PM
Wicksvolvo
Nov 14, 2011 10:29 PM
kzorn1989
Nov 9, 2010 11:36 AM
afa7
Apr 20, 2010 11:16 PM
