Emissions/No CEL
Old Jan 24, 2008 | 06:33 PM
MyDaughters740's Avatar
Default Emissions/No CEL
Hello all, am new to the Volvo scene, so pardon my initial ignorance.
Have a 91 740 with unknown mileage (apparently all 740's have no odo). Had the emissions done, and it did not pass. The car did not have a CEL, though it does light up when you turn on the key. And, the little black box on the strut tower--diagnostic box, I understand--gives no codes either. It seems like that little black box is dead, it doesn't even give a 1-1-1. Does this little boxcontrol the CEL, and if so, how can I fix this warning system?
Thanks in advance.
Old Jan 24, 2008 | 09:13 PM
Default RE: Emissions/No CEL
If you push the button does the LED light up?
If not open up the Button area and clean teh contacts. That may be why it isn't working.
Old Jan 25, 2008 | 12:27 AM
tedv's Avatar
How can the car not have a CEL if it turns on when you turn on the key?
BTW 740 odos are notworse than any other car's odo.
Old Jan 25, 2008 | 06:50 AM
Tech--No lights from the diagnostic unit at all. I'll try the contacts. It should be getting 12v from the ECU, right? I'm thinking that the unit's dead and not communicating to the ECU.....
TedV--I don't know, that's why I'm trying to track it down.
Old Jan 25, 2008 | 06:01 PM
Beardog's Avatar
you might be doing this, but I cant tell from the post.
the ignition needs to be in the on position for the diagnostic diode to work.
Old Jan 25, 2008 | 06:33 PM
The buttons get dirty all the time and don't work when pressed.
Old Jan 27, 2008 | 07:44 PM
Thanks for all your help.
Got it back from the shop yesterday, after they replaced the cat and passed emissions. Tested the diagnostic box, and now it works (dunno why, maybe the shop got it working....)
Thanks again.
Old Jan 27, 2008 | 07:54 PM
Glad it is all fixed.
matt01
Jul 23, 2012 11:12 AM
caligirl
Dec 28, 2011 05:54 PM
usawebx
Sep 2, 2008 06:11 PM
Gonzo
Jul 25, 2006 03:56 PM
no10socket
Dec 29, 2004 03:12 AM
