Engine damage? Timing belt issues B234F
Old Dec 27, 2008 | 07:04 PM
enthuesd's Avatar
Default Engine damage? Timing belt issues B234F
I was driving about 40mph and the engine dropped to idle for 5 seconds, the oil pressure light came on, and it shut off. It hasn't restart since. I took the valve cover off and cranked it and the cams don't move. I haven't taken off the belt cover, but either the belt broke or a pulley broke, possibly the oil pump since the oil light came on first.
According to this volvoclub link, the B234F engine will suffer damage if the belt comes off. If anyone else on the board has a second opinion or past experience I would appreciate it. I'm hoping that if this was an oil pump failure that the engine could still be functional with a simple replacement part or replacement belt, although the above mentioned link spelled out D-O-O-M quite clearly.
Is there any test besides pulling off the head for me to determine if there was any piston/valve collision?
Each spark plug was drenched in oil. This may be a hint.
Much thanks in advance for helping a newbee.
-mischa
Note: 1990 740 GLE B234F wagon.
Old Dec 28, 2008 | 10:13 AM
Default RE: Engine damage? Timing belt issues B234F
That is the 16 Valve motor isn't it?
If so then the valves will be bent.
Old Dec 28, 2008 | 01:57 PM
billofdurham's Avatar
The B234F is definitely an interference engine. Timing belt change every 50,000 miles.
Old Dec 28, 2008 | 04:56 PM
enthuesd's Avatar
Thanks for the responses.
I haven't had time to take it apart and inspect the insides, but is there any hope that a simple head swap could get this running again? Does the bottom of the engine usually suffer damage in these situations?
Old Dec 28, 2008 | 07:14 PM
If you were going slow or idling then the lower half should be fine.
Old Dec 29, 2008 | 05:12 PM
enthuesd's Avatar
About how much should a head rebuild cost?
ShaginWagon
Jan 23, 2013 08:29 AM
BGoins12
Jun 15, 2012 09:59 PM
ShaginWagon
Oct 18, 2010 11:23 PM
Mikesteve
Nov 5, 2009 06:46 PM
reedkm
Sep 22, 2009 07:42 PM
