Engine mounts 940 oem/Aftermarket
Old Jan 2, 2007 | 06:11 PM
lotusing's Avatar
Default Engine mounts 940 oem/Aftermarket
Hello again,
Well Tech is correct.I need motor mounts.Its not that bad but it vibrates a bit between 2.5 to 3k rpm's.This is driving me crazy because I like the car to be smooth. Is there a difference between oem and aftermaket other than the price?
Old Jan 2, 2007 | 09:17 PM
Default RE: Engine mounts 940 oem/Aftermarket
Not really that much. some are a little stiffer than the others.
Old Jan 2, 2007 | 10:12 PM
lotusing's Avatar
I am looking for the least stiff.Would know which is the best?
Old Jan 2, 2007 | 10:40 PM
NOT SCANTECH!!
They are hydrolic most are pretty good. Had problems with the scantech.
Old Feb 7, 2007 | 03:58 PM
lotusing's Avatar
Well I replaced the motor mounts and the problem is still there.I thought that this would fix it.The car vibrates when I rev the engine above the 2500 rpms.What is going on?
Old Feb 7, 2007 | 08:02 PM
JetTech's Avatar
This may be a long shot but I have seen this several times over the years. Remove the belts that go to your fan on your engine, start it up and see if you still have the vibration. On rare occasions I've seen where a fan blade gets either bent or becomes out of balance with a loss of a section of blade. Give that a try and see if the engine smooths out. If that's the problem you can get a fan out of a junkyard for next to nothing that will more then likely be ok. Just don't run the engine too long because your water pump won't be turning. Start it up without the belts, see if the vibration goes away, then shut it down.
Old Feb 7, 2007 | 08:27 PM
lotusing's Avatar
Thanks for the response.The car has an eletric fan so there isnt a belt driving the fan.
Old Feb 7, 2007 | 09:47 PM
I forget have we talked about the trans mount being bad yet?
Is it sitting on the cross member?
Old Feb 7, 2007 | 10:33 PM
lotusing's Avatar
I put a new trans mount and it made it worse.I put the old one back in.It seemed ok anyway.
Old Feb 7, 2007 | 11:08 PM
What brand is the mounts?
Can you rock the engine and feel the mounts working?
Or does it feel really hard and you rock the entire car and not see the engine moving?
Old Feb 7, 2007 | 11:21 PM
lotusing's Avatar
Volvo factory mounts.
Old Feb 7, 2007 | 11:23 PM
JetTech's Avatar
Sorry about that, I should have looked closer at your model. I get 240 on the brain and forget there are other models.....oooops!!
Old Feb 7, 2007 | 11:25 PM
lotusing's Avatar
I put on Volvo factory mounts.
Old Feb 7, 2007 | 11:56 PM
Check for movement like I described above and let me know.
Old Feb 8, 2007 | 01:15 AM
lotusing's Avatar
I will check the motor tomorrow.
thegazelle
Jul 17, 2014 03:36 AM
pezwack
Jun 22, 2011 06:57 AM
jmarble
Apr 22, 2010 07:41 AM
flyboy
Oct 27, 2008 03:44 PM
tr_car_nut
May 9, 2008 08:30 AM
